Anyone know if a 1994 cobra requires premium fuel?
Old 03-11-2007, 07:03 PM
Wick001
Wick001's Avatar
Default Anyone know if a 1994 cobra requires premium fuel?
Anyone?
Wick001 is offline
Old 03-11-2007, 07:09 PM
akshepard
akshepard's Avatar
Default RE: Anyone know if a 1994 cobra requires premium fuel?
some people might say you do, but im cheap i get 87 octane
akshepard is offline
Old 03-11-2007, 07:16 PM
ikeybmg
ikeybmg's Avatar
Only DOHC engines need premium. They might run better with it and the timing advanced but they dont require it.
ikeybmg is offline
Old 03-11-2007, 07:17 PM
notch5oh
notch5oh's Avatar
you shouldnt haev to, the motors arent that much different from a gt and they're meant to run 87
notch5oh is offline
Old 03-11-2007, 07:36 PM
Twisted
Twisted's Avatar
I guess most of the answer would be in the compression ratio of the Cobra. What is it, compared to a GT?
Twisted is offline
Old 03-11-2007, 08:42 PM
HACKGT350
HACKGT350's Avatar
only time it requires it is if you advance your timing
HACKGT350 is offline
Old 03-11-2007, 08:48 PM
gspfunk
gspfunk's Avatar
ORIGINAL: HACKGT350
x2. Cobra compression is similar or less than 5.0 HO. Unless you've bumped your timing (which I would recommend if you can afford premium every tank), you should be running 87 (or the low grade).
W/ stock timing, the higher octane gas will be harder to combust....overkill.
gspfunk is offline
Old 03-11-2007, 09:03 PM
90lxstang
90lxstang's Avatar
Look at what it recommends in the manual?
90lxstang is offline
11-10-2015 11:39 AM
tramphardrocker
09-13-2015 08:56 PM
algregory
09-11-2015 11:44 AM
Roush05
09-10-2015 12:23 PM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: Anyone know if a 1994 cobra requires premium fuel?
