weird squeaking in leftfront of stang? ideas?
Old 03-11-2007, 08:39 PM
Sick5.0LX
Sick5.0LX's Avatar
Default weird squeaking in leftfront of stang? ideas?
LIke I said, I have a squeaking noise coming from the left front of my 1990 5.0. It sounds like its almost inside the car, but im sure its something to do with the wheel (left front) cause it only does it when Im moving. Any ideas??
Sick5.0LX is offline
Old 03-11-2007, 08:54 PM
HACKGT350
HACKGT350's Avatar
Default RE: weird squeaking in leftfront of stang? ideas?
sounds like a ball joint jack up the front and a do a shake test if the wheel moves you need new ball joints and dont wait on them they are known to go on the stangs and its not going to be a fun ride when you doing 50 down the road and it snaps and the car flips *** over head
HACKGT350 is offline
Old 03-11-2007, 09:50 PM
93 LX FiveO
93 LX FiveO's Avatar
grease it if it has a fitting
93 LX FiveO is offline
Old 03-11-2007, 11:19 PM
Sick5.0LX
Sick5.0LX's Avatar
It's actually not a "squeak"... it's more of a scratching actually. The scratching gets faster and the car goes after, and slows down when the car slows down..
Old 03-11-2007, 11:24 PM
89 5.0 Mustang
89 5.0 Mustang's Avatar
It could be a wheel bearing. My friends 94 Gt might have the same problem as you.
89 5.0 Mustang is offline
Old 03-11-2007, 11:30 PM
dillon1340
dillon1340's Avatar
if your talking about the car in your post, the red one. check the front wheels to see if the caliper is rubbing. i have the same wheels and if i'm not super careful when i put them on the caliper scratches on the inside of the wheel.
dillon1340 is offline
Old 03-12-2007, 01:31 AM
Sick5.0LX
Sick5.0LX's Avatar
ORIGINAL: dillon1340
Ill check this out! What would the fix for the calipers rubbing be?
Old 03-12-2007, 02:32 AM
93 LX FiveO
spacer
Old 03-12-2007, 03:08 AM
Sick5.0LX
Sick5.0LX's Avatar
haha duh... I shoulda figured that one out myself. Thanks...
Old 03-12-2007, 03:09 AM
AlabamaCobra
AlabamaCobra's Avatar
probably just a kitten under the hood gettin ground up into bite size pieces.
AlabamaCobra is offline
Quick Reply: weird squeaking in leftfront of stang? ideas?
