what sensor is in the block? *now with a pic*
RE: what sensor is in the block?
if memory serves there is an oil galley going up to is that you can see from the back of the motor... lemmie go check the core in my garage
*edit* i just looked, there is a oil galley up there but its blocked with a freeze plug and could only be seen with the intake OFF.
where your sensor is, theres nothing cast into my block at all, hell you should be able to see the bottom side of where that is screwed in.... im kinda confused at this point because the block i have out there is a one piece rear/roller block and there were no changes that i knew of in the blocks from mid 80's-up
jwog666
12-27-2021 08:09 PM
