Dyno tune gains
Dyno tune gains
I know this is a very blunt question. How much hp do you think i can gain with a dyno tune. I'm getting one done next month but I have know clue what to expect. Will it be a 10hp gain or 50hp. I will have 24lb injectors installed as well then.
RE: Dyno tune gains
yepper....if they have a wideband..they might be able get a few out...i gained 35hp 50tq..but that's just timineg and fuel...now if they can burn a chip possibilities are out there.
RE: Dyno tune gains
dyno tune is when you bring your car to a performance shop, they strap it on a dyno, and adjust stuff in your computer to make your car run better
you do not need, nor can you use a handheld tuner, like the diablo sport predator.. they are OBD2 only
RE: Dyno tune gains
i know there will be more replies on this...but...when they strap your car down they stick two probes kinda like the smog police have and when your car is underload it real read your exhaust to see if you are rich or lean..the one i go to has a egt reader..and i think that is more usefull...anyways your air to fuel can be manipulated by fuel pressure,and timing...if you have no chip being burnt...never let anybody charge you $$$$ if that all you got to be changed...it's not like they can change your shift points injector spread.....if you know what to do then do it yourself
RE: Dyno tune gains
ORIGINAL: AdderMk2
you know i had a tuner say they can use one[&:]...i hung up when they started bashing pms,and megasquirt<had to throw that at ya
