TFS 1
Old 03-12-2007, 05:51 PM
jtmustang
jtmustang's Avatar
Default TFS 1
we'll i just ordered my tfs 1 cam lifters timiming gear set gaskets arp rod bolts ,and some other things so i have heard good and bad with this cam well i will be experiencing it for myself now with .030 trw's cast ported gt'40's 65mm tb,73maf ,full exhaust ,trickflow intake ,crane 1.6 roller rockers,hi flow waterpump,what numbers would u might except anybody else with similiar setup.
jtmustang is offline
Old 03-12-2007, 06:22 PM
jtmustang
jtmustang's Avatar
Default RE: TFS 1
come on i know there are a fair amount of people using this cam
Old 03-12-2007, 06:26 PM
Joel5.0
Joel5.0's Avatar
Default RE: TFS 1
Really hope you have a valve springs upgrade kit incuded......
Joel5.0 is offline
Old 03-12-2007, 10:48 PM
92hatchLX
92hatchLX's Avatar
Default RE: TFS 1
I've got it, I've also got some similar modifications to you. I love it, it makes good power and the power band isn't too high, very EEC friendly. Good pick, especially with those GT-40 heads. I'm not sure if you have it or not, but you'll need the TF spring upgrade kit. Unless you bought the heads assembled with stiffer springs.But if you ordered it and didn't list it you're good to go
92hatchLX is offline
Old 03-12-2007, 11:12 PM
jtmustang
jtmustang's Avatar
Default RE: TFS 1
yeah the springs are some kind of aftermarket spring the shop were they were said that they were good for .600 of a lift so i should be fine
Old 03-12-2007, 11:14 PM
92hatchLX
92hatchLX's Avatar
Default RE: TFS 1
Yep, you'll be good.
uedlose
The Racers Bench
10-01-2015 08:31 PM
Jacob4589
08-17-2015 09:34 PM
Jacob4589
08-08-2015 11:00 AM
stanglx2002
01-22-2006 02:11 PM
1990mustanggt
10-31-2005 01:25 PM
Quick Reply: TFS 1
