Harmonic Balancer
Old 03-13-2007, 12:06 AM
Dubs
Dubs's Avatar
Default Harmonic Balancer
Guys what exactly is this and does it need to be changed when you upgradeto H/C/I?
Dubs is offline
Old 03-13-2007, 12:26 AM
90Lxstanger
90Lxstanger's Avatar
Default RE: Harmonic Balancer
ORIGINAL: Dubs
Its exactly what your tpoic says, Its a 50 oz. weight(balancer) then mounts to the crankshaft to dampen the vibraton-also called and crankshaft dampener, and no you shouldnt need to change it unless its bad-all 5.0s use 50 oz- if i recall right
90Lxstanger is offline
Old 03-13-2007, 12:40 AM
FullAuto
FullAuto's Avatar
You don't change it unless you're using a stroker (and not always then) or an older, non-roller block crank like a 2M or 2MA.
FullAuto is offline
Old 03-13-2007, 12:43 AM
90Lxstanger
ORIGINAL: FullAuto
Really stroker's require the 28 oz? is it, thats strange
Old 03-13-2007, 12:49 AM
FullAuto
FullAuto's Avatar
ORIGINAL: 90Lxstanger
ORIGINAL: FullAuto
An overwhelming majority do. You can buy some 50oz. 331/347 kits, but most are 28oz. All my Scat 8.2" stroker stuff is 28oz (or 0 balance).
FullAuto is offline
Old 03-13-2007, 12:52 AM
90Lxstanger
Hmmmmm..............neat-o
Old 03-13-2007, 01:37 AM
LTnone
LTnone's Avatar
Keep your stocker. When you take it off use a balancer puller ($13 at Autozone). There is a washer where the crank bolt holds it to the crank, make sure to take that out before trying to pull it, or you will get nowhere. When it's going back on put some white engine grease inside the balancer's hole, and line the keyway with black rtv.
LTnone is offline
Old 03-13-2007, 10:49 PM
Dubs
Dubs's Avatar
Reason I asked is because 1st my friend will be doing my H/C/I swap and said I need it. 2nd I didnt know what it was for.
I will not be going with a stroker anytime soon. But he did say what I will need is the Powerbond 50oz SFI approved? I still have no clue.
Please help explain....
Dubs is offline
Old 03-13-2007, 11:14 PM
90Lxstanger
ORIGINAL: Dubs
This might help - http://www.wilmink.nl/wilmink/produk...dCatalogue.pdf
Its just a better balancer
Old 03-14-2007, 04:09 AM
Dubs
Dubs's Avatar
Good find! It helped me a lot.
Thanks!
ORIGINAL: Dubs
Dubs is offline
mtgldr
02-03-2024 09:00 PM
jessicarabbit
09-25-2015 12:41 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
Quick Reply: Harmonic Balancer
