not running right?
Old 03-13-2007, 02:11 AM
9165pt0
9165pt0's Avatar
Default not running right?
hey guys just got gt40 intake and heads installed on my car, and it seems to lag and not want to go anywhere until it hits about 3500 rpm. big lack of power over stock down low, when u punch it...the car hesitates and just sounds loud but doesnt get up. the maf and t/b still need to be changed out and they are still stock...could this be the problem? any other suggestions
9165pt0 is offline
Old 03-13-2007, 02:23 AM
kev2369
kev2369's Avatar
Default RE: not running right?
Valves adjusted corretly?
kev2369 is offline
Old 03-13-2007, 02:24 AM
9165pt0
9165pt0's Avatar
how can i figure that out?
9165pt0 is offline
Old 03-13-2007, 02:25 AM
Scout2232
Scout2232's Avatar
Stock cam?
Scout2232 is offline
Old 03-13-2007, 02:33 AM
9165pt0
9165pt0's Avatar
thumper gt40 heads and gt40 intake, yeah stock cam stock maf and stock t/b. but its not jsut a lack of power, i mean theres no power at all down low and it hesitiates. even while you floor it the rpms barely move, but once they get up to about 3000-3500 or so they fly up 6000.
9165pt0 is offline
Old 03-13-2007, 02:37 AM
kev2369
kev2369's Avatar
Are you running pedestal mount or stud mount roller rockers?
kev2369 is offline
Old 03-13-2007, 02:45 AM
9165pt0
9165pt0's Avatar
stock rockers from a 1992 5.0
9165pt0 is offline
Old 03-13-2007, 02:46 AM
9165pt0
9165pt0's Avatar
could it just be that the stock maf and t/b arent moving enough air? because thats what the car sounds like when i floor it, it seems as if its choking. or is it soemthing more serious? plaz any suggestions will help, jsut trying to get my car running right
9165pt0 is offline
Old 03-13-2007, 02:51 AM
kev2369
kev2369's Avatar
Well they should be pedestal mount.... They should have been torqued down to 20lbs...The mass air is unlikely the problem... Larger ones would help a little, but they won't solve that problem... Does the engine idle fine? No vacuum leaks or anything?
kev2369 is offline
Old 03-13-2007, 03:01 AM
9165pt0
9165pt0's Avatar
engine idles fine, it wasidling a lil high and the timing was adjusted and now it idles right under 1000 rpm like always. if i rev the rpm slowly it sound fine, but if i rev them up quick everything seems to hesistate and bog down and sound like somethins choking and its rough. and when driving its ok but when you give it some gas it just sounds louder than usual and ****ty and wont go anywher...rpms move slow and it wont pick up...but once it gets over about 3500 rpm theres good power.
9165pt0 is offline
Quick Reply: not running right?
