Engine Pros: this doesn't sound right... video
Hey guys,
Here's a link of my engine running, and thecar sounds like hell.
What do you guys hear? Suggestions?
Finally busting out the car for spring, only to hear this, is really a bummer.
I appreciate the help! [&:]
http://www.youtube.com/watch?v=r87Xxw6GKJE
PS:I just changed the oil today, it sounded exactly the same before and after
RE: Engine Pros: this doesn't sound right... video
ORIGINAL: LesteR723
my friends 306 does the same thing... its just his lifters tapping. add some oil!
try putting some Seafoam in the oil, see if it frees it up
did you change anything out, lifters, rockers etc????? with my new 1.6Fs and new lifterss they made a lil more chatter than my stockers, and now i have replaced lifters with PRO Magnum Hyd Roller Lifters and kept my 1.6Fs and they make even more noise now, but everythign is running fine,, G-damn loud lifters
WTF???? lifters? did you check your oil pressure?
tighten your header bolts
if u havent driven it in a while chances are ur lifters bleed down.. let it ildle for a while and it should go away
Take the driveside valve cover off and see whats up.
sounds like a broke or stuck valve train piece to me
I appreciate the help... when I get this back together I could try some seafoam. Any other ideas? This is killing my spirit...
[IMG]local://upfiles/15172/89610D169D6A4C11A7807CE929C69CF1.jpg[/IMG]
