my AOD has been acting up lately?
Old 03-13-2007, 09:22 PM
blk89lx
blk89lx's Avatar
Default my AOD has been acting up lately?
ok got a quick question. my aod has been acting up lately dont know whats wrong. the other day when i started it up after school i put it into reverse and it went no where then like 5 seconds later is grabbed and went into gear. then the other day i put it into drive and it just slipped i think and went no where. also i will like waiting at a light or a stop sign and when i take off the tranny will slip and the rpm's will go up then the tranny grabs and its fine? have no idea what this can be is it possible that my tranny could be going its got 117k on it.
blk89lx is offline
Old 03-13-2007, 09:29 PM
Skyler5.0
Skyler5.0's Avatar
Default RE: my AOD has been acting up lately?
sounds like valve bodys going or clutches, whens the last time you change or checked the fluid??
Skyler5.0 is offline
Old 03-13-2007, 09:30 PM
92hatchLX
92hatchLX's Avatar
It wouldn't surprise me if it is slipping. Sounds like it is time for a tranny rebuild and don't go with stock junk. Have you ever flushed it or at the least changed the fluid and filter?
92hatchLX is offline
Old 03-13-2007, 09:41 PM
p1bigun
p1bigun's Avatar
check your oil
p1bigun is offline
Old 03-13-2007, 09:42 PM
nitrous_bob
nitrous_bob's Avatar
yup it's toast, could be a number of reasons, od band usually the first to go, clutch packs, converter, any of the above, all of the above
look at getting a lentech, stock rebuild is expensive and sux
nitrous_bob is offline
Old 03-13-2007, 10:24 PM
luckythirteen13
luckythirteen13's Avatar
sounds like its going out but id check the oil level before i spent any money
luckythirteen13 is offline
Old 03-13-2007, 10:28 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
man sound like ford techs in here as all you guys here say trans is gone before trying some cheap stuff
check field, is it bright red? does it smell burnt? spend 30 bux and change the fluid and filter
2 kwik is offline
Old 03-13-2007, 10:33 PM
92hatchLX
92hatchLX's Avatar
I would assume that he would be smart enough to check that without saying anything.
Old 03-13-2007, 10:36 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
in here my friend assume nothing
2 kwik is offline
Old 03-13-2007, 10:44 PM
92hatchLX
92hatchLX's Avatar
ORIGINAL: 2 kwik
That's true
Quick Reply: my AOD has been acting up lately?
