Smog pump delete...what length belt do I need?
Old 03-16-2007, 03:15 PM
VigCS
VigCS's Avatar
Default Smog pump delete...what length belt do I need?
I would go outside and just use a string but it's icing/sleeting/snowing like hell out there right now. I've got a 92.25" belt on right now with all of my accessories...what size should I go down to? Adv. Auto has 90.5", 87.5", 86", and 84.5". What do you all think? I'm thinking 87.5" cause it'll shorten it 4.75" and any extra slack the tensioner could pick up. Thanks guys.
VigCS is offline
Old 03-16-2007, 03:18 PM
black89gt
black89gt's Avatar
Default RE: Smog pump delete...what length belt do I need?
850K6. but you route it a different way. like this.
http://www.moddedmustangs.com/forums...ng_166_169.jpg
they use a 84.5 inch belt, but many people on this forum who have done it use the 85.0 belt. good luck. hope that helps
black89gt is offline
Old 03-16-2007, 03:20 PM
VigCS
VigCS's Avatar
I don't need to route it a different way, just bypass the pump 'cause it doesn't change the direction at all. Your image is broken too...
Whats an 850K5? Thanks!
Also, I'm using a water pump pulley from an '86 which is a little bit bigger, requires about an extra 1"-1.5" of belt length, so I'm thinking an 87.5 will do the trick.
VigCS is offline
Old 03-16-2007, 03:22 PM
CarJway
CarJway's Avatar
Your talking about just literally bypassing the smog pump. That’s how I have it on my mustang. When I get out of work, I will get the belt length/number for you.
CarJway is offline
Old 03-16-2007, 03:24 PM
VigCS
VigCS's Avatar
ORIGINAL: CarJway
Yeah, I'm taking the pump off. Are you using a stock water pump pulley? What time do ya get off work?
VigCS is offline
Old 03-16-2007, 03:35 PM
88BlueGT
88BlueGT's Avatar
I asked the same question a few months ago and got 10 different answers. Everytime I went to the parts store and tried them... none of them fit lol If I were you I would just go and buy a few belt and try them. Start with the smallest one and work your way bigger. Than take the rest back.
88BlueGT is offline
Old 03-16-2007, 03:41 PM
CarJway
CarJway's Avatar
I am running a 3G alternator, A/C, P/S, and fatory Water Pump Pulley.
I get out around 5'ish
CarJway is offline
Old 03-16-2007, 03:46 PM
Wisconsin 5.0
Wisconsin 5.0's Avatar
ORIGINAL: VigCS
I have a 90 GT with no air pump....NAPA part # 060837
I am running everything else...and stock pullys
20mm X 2140mm
You will need to run belt a little different from stock routing
Wisconsin 5.0 is offline
Old 03-16-2007, 04:06 PM
REDS 5.0
REDS 5.0's Avatar
I used a 84.5 belt. Its a tight fit but okay!
REDS 5.0 is offline
Old 03-16-2007, 05:20 PM
VigCS
VigCS's Avatar
ORIGINAL: Wisconsin 5.0
ORIGINAL: VigCS
20mm X 2140mm
How so? Any diagram or pic available to show how it needs rerouting? Thanks!
VigCS is offline
Quick Reply: Smog pump delete...what length belt do I need?
