everyones specialties
ok so im just kinda curious, whats everyones strongest points w. our cars?
for example, manual trannys, and sd are mine... curious to see whos good or better at what
RE: everyones specialties
Well as far as the 5.0 goes, not much. Just got it a month ago, I do well with electrical, common knowledge on some of the main reasons for failures. Figuring out what is broken is normally no problem, but not specifics on the 5.0, thats why I am here. BTW what can I do with my sd car dimebag.
ORIGINAL: tmajikman
ORIGINAL: georgiaguy246
since your good at figuring out failures and electrical stuff. want to come over and figure out what the heck is wrong with my fuel pump getting power? lol
ORIGINAL: tmajikman
ORIGINAL: AdderMk2
find the relay signal wire at the ECM, cut the wire.
connect (solder preferably) and tape (shrink tubing preferably) a new wire lead to it.
run the new wire to a suitable location... stock location is fine.
run a fused 12v source wire to that same location.
Install a BOSCH 5 pin relay with +12v as circuit close trigger. I like these!
make a ground to chasis.
run a signal wire back into your trunk to the old +12v feed wire.
Cut the old wire, connect (solder preferably) and tape (shrink tubing preferably) the new feed wire to the pump.
Now you will have 4 wires at the relay, and hopefully a relay harmess... If not, use female spade connectors (insulated preferably), and connect the wires to your relay.
Im not sure what my "specialty" is... maybe its being an *******!
