302 Cast Iron Head Flow Numbers
Does anyone know what the combustion chamber size is on a 1986 Ford F-150 with a 5.0? Also what is the combustion chamber size on the Mustangs around that same year? If anyone has all the flow numbers for both vehicles that would be great!
RE: 302 Cast Iron Head Flow Numbers
just did some research and updated my original post.... and yeah the E6's are junk.
funny though, i (very cheaply) built a 302 with a 218/228 .471/.471 cam and the E6SE heads with pistons a 78 302 and a dual plane ford aluminum intake from a early 80's stang (which had ports as small as the 255's [:@][:'(][&:]). stock exhaust manifolds and single exhaust out the back, (and a holley 600 4barrel from a ford van in the junk yard ). i'll tell you what you would think it woulda been the biggest dog ever - and it was over 4500-5000 rpms..... but off the line that thing would absolutely destroy the back rubber. very surprizing but damn damn damn that thing was insane off the line.
ORIGINAL: my77stang
The engine I am working with has:
1986 E-150 stock bottom end 90,000 miles never been rebuilt, and stock heads with stock springs, and valves.
Holley Contender single plane intake manifold
Demon 625 CFM 4 barrel carburetor with vacuum secondaries
Crane Energizer 272/272, Lift .533/.533 hydraulic flat tappet cam
Its not the best setup, but its what was laying around the shop. All I really want to do from this point is to replace the cast iron heads for aluminum ones to save some weight, and to maybe pick up a little horsepower.
