wierd whistling noise?!?!?
hey everyone my name is mike im new on the site and i have a question. i have 93 mustang gt with a gt40 intake. i recent got a wierd whistling noise from under the hood. i retightened the whole intake so0 i know there no loose bolts on the intake itself. could it be possible the fuel pressure regulator is not working properly to cause that noise ??? let me know ...thanks !!!!
RE: wierd whistling noise?!?!?
Could be a vac leak...check around for loose vacuum lines. Get a can of gum cutter and start spraying around all the vac lines and listen for a change in RPMs.
You sure someone didnt secretly install a charger while it was in storage? [8D]
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
