trickflow heads?
Old 03-18-2007, 07:24 PM
jtmustang
jtmustang's Avatar
Default trickflow heads?
we'll im thinking real hard about saying fu#@ it and just ordering a set of their heads since i will be runnin tfs intake ,and tfs stage 1 cam and i hear that their stuff makes better power when it is used together because i want to get to 300 rwhp my setup im gonna run about to pull motor is
tfs intake
tfs 1 cam
crane 1.6 roller rockers
65 mm bbk tb
76 c&l maf
.030 trw's
underdrive pullies
bbk unequal headers
bbk h-pipe
bbk cold air
flows out the back
cast gt-40's ported and been shaved like.025's off a 93' cobra
so what do u think for numbers with this setup i know im not gonna hit 300 rwhp with this that is why im wanting to get a set of twisted wedge heads waht do u think
jtmustang is offline
Old 03-18-2007, 07:32 PM
jtmustang
jtmustang's Avatar
Default RE: trickflow heads?
any one have any info for me
Old 03-18-2007, 07:36 PM
LTnone
LTnone's Avatar
Do you already have the cam and intake? If not, just buy a top end kit. Lot cheaper for everything. Get a 70mm TB, and you'll need different length (and hardened) pushrods with different heads.
LTnone is offline
Old 03-18-2007, 07:39 PM
stangman94
stangman94's Avatar
When people say they don make 300rwhp do they meanthey didn't make 300rwhp without a dyno tune or with one because the tune makes a big difference.
stangman94 is offline
OnyxCobra
OnyxCobra's Avatar
Idk what to think, I've seen a lot of TFS top end kits fall short of 300whp.
OnyxCobra is offline
Old 03-18-2007, 07:45 PM
Ninety5five0
Ninety5five0's Avatar
ORIGINAL: OnyxCobra
+1, have you thought about AFRs ? Right around the same price.....You gettin it tuned too ?
Ninety5five0 is offline
Old 03-18-2007, 08:02 PM
jtmustang
jtmustang's Avatar
yes i already have the intake and cam everything i listed i allready have ,and yes when i get all done and running i am going to get it tuned .have not tore the motor out yet am just about ready to but i want to get close to 300whp.but like i said and u will probably agree the cast gt-40's are not going to get me there. what kind of numbers? yes i really want the afr's but i thought that matching everything would get me more hp or am i wrong?
Old 03-18-2007, 08:06 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
WHY NOT BUY A USED SET AND THE $$$ YOU SAVE YOU COULD HAVE THE INTAKE AND HEADS EXTURD HONE
2 kwik is offline
Arrid Extra Dry
Arrid Extra Dry's Avatar
all that sounds good....
i recomend TF heads
the stage 1 TF cam is ok, and is a very good camshaft, i ran one for a little while
i replaced the TF 1 camshaft with a ford motorsports X camshaft, and it picked my car up
alot!!!
the X Cam is an all around better camshaft, than the TF stage 1
but you can run the TF stage 1 on factory pistons, you cant on the X camshaft, as far as i know.
im running 7.0s on the motor, with out of the box twisted wedge heads.
in my opinion, they are an all around better head than any other(out of the box).
i would buy TF before any other head, if you didnt want any port work done too them.
Arrid Extra Dry is offline
Old 03-18-2007, 08:08 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: jtmustang
I've seen AFRs and Alphabet cams make higher numbers than the trickflow top end kit, so all that matching stuff does not always make more power.
Quick Reply: trickflow heads?
