Help! Lets play is it VALVES or LIFTERS! (vids)
RE: Help! Lets play is it VALVES or LIFTERS! (vids)
I assume it is stock hyd rollers. I havent had the car long. I tried to press down on the rocker arms looking for a weak roller. But they all seamed firm.
ORIGINAL: highway21
check preload?
check preload?
Well.... I got it all appart today. The heads looked fine. Valves from what I could see were okay'. But, I am quite sure that the one of the valve seals isnt perfect or I wouldnt me getting smoke from my breather. Now to the lifters. They look fine. But I think one may be stuck. Anyone know just how much pressure it takes to get them to give at all? Because there is no really noticable problems. I will be pulling out the cam tomorrow.[>:]
how many miles on the bottom end? can you catch your fingernail on the ridge at the top of the cylinders? if so its getting time for a rebuild
Not a whole lot. 90k on it. Bottom end turns smooth and looks fine. I wont touch the bottem end. It would cost me more to rebuild it than it would to buy one rebuilt. I dunno'... I was hoping to see a clearer problem. Though I am thinkin' lifters. I'll see what the cam looks like soon enough. I may just replace it all while it is appart. But that is expensive.
def. do a cam while your this far into it. MAKE SURE you keep the bottom end CLEAN when you reassemble or you'll be rebuilding the whole thing soon enough. gasket crap and grit likes to hide between the piston and the cylinder from the top of the piston to the first compression ring. if you got an air compressor, a blower nozzle is your best friend.
i'd take the heads in and get a valve job while they are off, you'll get your new seals and you'll be able to have them knock down the guides a bit and install those new springs you'll be wanting for your new cam
VJ with a resurface shouldnt be more than 250.00 (which is even high IMO) and they shouldnt charge jack shiat to knock the guides down. hell you can buy the tool from goodson and do it yourself with a 3.8 drill for like 65 bucks
