modded but still guttless! why?
Old 03-22-2007, 01:50 AM
  #81
vristang
vristang's Avatar
Default RE: modded but still guttless! why?
ORIGINAL: tortugasmoker
ORIGINAL: AdderMk2
ORIGINAL: frdmstng1986GT
ORIGINAL: vtecwho
is it possible that the stock MAF can be calibrated?? ive heard of people doing a 70mm MAF conversion.... or somthing like that. or does it physically have to be bigger.
the pic of my upper mainfold should show up.... as you can see it is a gt 40, not a cobra, like what was suggested before.
the size of the maf has nothing to do with the calibration of it.. it all has to do with the sampling tube and the electronics in the maf itself. a stock maf is calibrated to 19lb injectors and you have 24lb injectors and youre computer is calibrated for 24lb injectors,thus the reason why youre car is not running to it's full potential. i'm not too up on what the best aftermarket mafs that are out there are but hopefully someone will chime in and let you know what is the best one to get.
you guys really need to drop it with this "calibrated maf" crap...
MAF's dont have a calibration.... the ability to run a certain size injector has to do with the programming of the ECM.
a 19# "calibrated" MAF will work fine on a cobra computer, since its tune is varied from the stock A9* computer...
yeah i totally agree, i have an 89 with cobra u/l intake, ported e7s, cobra ecu, cobra MAF, and 19 pounders and it runs like a champ.
I don't know how I missed this, but it is wrong...
A 93 Cobra computer, with a 93 Cobra MAF, and 19lb injectors is NOT running properly.
You should be running 24lb injectors, or get a custom tune...
ORIGINAL: AdderMk2
I'm not even sure what you are getting at here...
Ifone usesa 93 Cobra computer, then you MUST use 24lb injectors and a 93 Cobra specific MAF/MAS unit.
If aftermarket parts are being discussed, then that is a completely different scenario.
jason
vristang is offline
Old 03-23-2007, 11:46 AM
  #82
mustangfxbdy
mustangfxbdy's Avatar
wouldnt hurt to do a compression test to make sure she is a happy engine...
mustangfxbdy is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
TimeLord101
10-01-2015 06:40 AM
firecoyote
09-27-2015 02:37 PM
Quick Reply: modded but still guttless! why?
