what should i do to the engine??????
Old 03-19-2007, 11:39 PM
mustang95gt
mustang95gt's Avatar
Default what should i do to the engine??????
on my list are 70mm TB,trick flow manifold, but what else should i get???????? by doing these mods should i get more gas going through the engine to make the air to gas ratio equal??????
mustang95gt is offline
Old 03-19-2007, 11:45 PM
Chubstang
Chubstang's Avatar
Default RE: what should i do to the engine??????
you could get an adjustable fuel regulator. How much do you have to spend. If you can afford it get a set of heads and a cam. If I were you I would get gears and an exhaust.
Chubstang is offline
Old 03-19-2007, 11:46 PM
Chubstang
Chubstang's Avatar
oh and you could try searching or looking through the tech articles.
Old 03-20-2007, 12:06 AM
johnjr45
johnjr45's Avatar
heads cam
johnjr45 is offline
Old 03-20-2007, 12:13 AM
92hatchLX
92hatchLX's Avatar
The computer will adjust your A/F ratio as needed. Install some gears and do a full exhaust.
92hatchLX is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: what should i do to the engine??????
