MAF sensor Question
RE: MAF sensor Question
http://www.promustangperformance.com/aem-30-4100.html
put the name Keith in your order under the "comments" section
What is the "ideal" set up on MAF sensor, T/body, and EGR plate if the intake has a T/B opening of 75mm? I have a 75mm MAF sensor? should I go with 75mm T/B and Plate or 70mm?
Sizing wise it is generally accepted to keep the MAF a little larger than the TB.
It doesn't need to be much, 5-10mm would suffice. You just don't want the MAF to be the choking point in the inlet tract.
jason
jason
ORIGINAL: 91RedHatchback
Thanks,
so a 75mm,75mm,75mm, would be acceptable right?
Thanks,
As for the MAF question, as stated earlier the MAF is still used in supercharger applications. I mean how else would the cars computer measure how much air the engine is using? As for location, IMO you shoulduse a Draw-thru MAF set up (like just about every supercharger company on the planet, besides Pro charger, uses). That is where the MAF is mounted to the intake side of the superchargerrather than the outlet (boost) side.
