Oil for the 5.0??????
Old 03-20-2007, 11:45 AM
decipha
decipha's Avatar
Default RE: Oil for the 5.0??????
I put in 5 quarts of 10w30 and my stick shows right at full... i know this doesn't help any but just my .02
decipha is offline
Old 03-20-2007, 11:56 AM
88BlueGT
88BlueGT's Avatar
My dipstick never seems to read correct. I put 5qt's in regardless.
88BlueGT is offline
Old 03-20-2007, 02:07 PM
92hatchLX
92hatchLX's Avatar
If you've got sludge build up in the oil pan it can decrease the amount of oil that your pan will hold. I have the same issue with my dipstick,4 qts. and it reads full, I dunno what gives.
92hatchLX is offline
Old 03-20-2007, 02:15 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
because you have one of those engines that had the wrong dipstick in it....mine has the same dipstick which reads overfilled with 5 qts...I just made a make for 5 qts. this issue was in a stealership bulletin
2 kwik is offline
Old 03-20-2007, 02:19 PM
LIL D
LIL D's Avatar
not one fox body that i have owned has the dipstick been right with five qts in it it always read a qt over so i just made a new line on the dipstick problem solved
LIL D is offline
Old 03-20-2007, 02:22 PM
92hatchLX
92hatchLX's Avatar
When you guys do your next oil change, fill it up with 4 qts., take a file andmark the dipstick and that's your low mark, put 5 in it and mark it and that's your full mark.
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
wraith777
09-28-2015 10:49 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Oil for the 5.0??????
