Timing
Old 03-20-2007, 01:33 PM
kevman41635
kevman41635's Avatar
Default Timing
I have tried the Search feature but it does not work right know for some reason. My question is what is the base timing set at and on a stock motor it is a 1994 5.0, what is safe to go up to. I know it all depends on the motor and just drive it and listen for it to ping but i just wanted a starting point.
Thanks
Kevin
kevman41635 is offline
Old 03-20-2007, 01:41 PM
1985stang
1985stang's Avatar
Default RE: Timing
Base timing on all 5.0's is 10*. I've heard of people going up to 14* but i think you have to run premium if you set it that high. I guess a good place would be 12*
1985stang is offline
Old 03-20-2007, 06:42 PM
kevman41635
Default RE: Timing
bump
Old 03-20-2007, 07:09 PM
grumpyphillips
grumpyphillips's Avatar
Default RE: Timing
Start at 10* and then slowly go up. Once you hear it pinging, back off a degree or two.
grumpyphillips is offline
Old 03-20-2007, 07:13 PM
88BlueGT
88BlueGT's Avatar
Default RE: Timing
Check out the stickies... we have a tech article in there! It should be set at 10 unless it has been tampered with. Move up to 12 and take it for a drive. No pinging, bump it more, no pinging bump it more, etc until it pings and than back it down a degree. Also, make sure whatever octane you want to run you have a full tank of. You can run more timing if you go to a higher octane.
88BlueGT is offline
Old 03-20-2007, 08:31 PM
SN95Stang
SN95Stang's Avatar
Default RE: Timing
i hav a 95 5.0 and i have it at 14*.......18* was too much for me....im running 93 all the time tho.
SN95Stang is offline
Old 03-20-2007, 09:08 PM
nitrous_bob
nitrous_bob's Avatar
Default RE: Timing
actually you can be lean and not hear it at all.
reading the plugs helps, but track time is the best way.
as far as numbers...stock could range from 0-12* they were pretty crappy about it if it's never been changed.
10* is safe on 87 all day long, 12* is safe on 87 if it's cool out, i wouldn't go higher than 14* unless your running premium though.
make sure you remove the SPOUT after you start it, but b4 you change it, or it will not take it right.
if you wanna powertime it, at the track...... make a run on 10* then make runs bumping it 2* per run, don't worry about ET, but the mph that is highest is where your making the most power, and the best time for you.
nitrous_bob is offline
mungodrums
10-07-2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: Timing
