clutch problems
clutch problems
got a hayes part # 95-201 500 horse clutch not that its important to know but my question is where is the thing supposed to engage and disengage? i been told that should be lower to the floor but its closer to the top. also have a bbk firewall adjuster and a double quadrant and hd cable. plus that stinkin throwout bearing squeals! what can i do?
RE: clutch problems
no, you need to adjust it right away.
it should start to engage about 1-1/2" off the floor
if it's towards the top too much your not fully engaged
does the t/o bearing squeal when you rest your foot on the clutch pedal ? and did you do a steel bearing retainer ? the aluminum one is probably chewed up like they do so easily.
RE: clutch problems
I just bought a new clutch today.
http://cgi.ebay.com/ebaymotors/KING-...93564149QQrdZ1
I see someone said something about a bearing retainer should i buy one of them also? If so what kind and where to find one?
RE: clutch problems
you don't NEED one unless yours is worn, but they are cheap and a good inmprovment
ORIGINAL: DIMMER
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
