Want a Free Dyno Pull?
Old 03-24-2007, 07:52 PM
  #21
w8less
w8less's Avatar
Default RE: Want a Free Dyno Pull?
hey i have the same program so i will let you know also
w8less is offline
Old 03-24-2007, 07:55 PM
  #22
w8less
w8less's Avatar
ORIGINAL: r.barn
This should be good.
I know my engine made 465-475hp at 6,000rpm on a "real" engine dyno
Lets see what the computer says.
bore = 4.03
stroke = 3.5
heads = AFR 185's w/ 145 springs
cam = .579/.579lift, 236/248 duration at .50, 112 LS, roller cam
10.2 compression
intake = VicJr.
carb = 750
exhaust = 1 3/4 LT's
468/483
[IMG]local://upfiles/12612/199AB824D36648428D56EA68D492CBFE.jpg[/IMG]
w8less is offline
Old 03-24-2007, 07:57 PM
  #23
90Lxstanger
90Lxstanger's Avatar
Hey would you run mine, if you dont mindThanks
90Lxstanger is offline
  #24
w8less
w8less's Avatar
post info
w8less is offline
Old 03-24-2007, 08:01 PM
  #25
90Lxstanger
Bore-4.00
Stroke- 3.00
Heads-ported E 7's(port matched)
Cam-stock
Intake-Cobra-port matched to heads
Comp. Ratio- stock
Exhaust-BBK-equals/no cats/Mac Muffs/ 2-1/2 in.
Give that a whirl, and thanks
Old 03-24-2007, 08:04 PM
  #26
my77stang
my77stang's Avatar
jasper i was trying to figure out why our numbers didnt match on that 351w, then i realized you entered in his cam specs at seat to seat instead of @ .050 - can you fix that and let me know the peak HP? be nice to see it ran on two separate machines and get the same number.
90LX, what kinda port work is done, just ex bumps and matching? or are they hogged to hell like thumper heads? it makes a big difference in the flow chart
also, i still dont have stock cam specs, and how many cfm's a stock throttle body flows and what a upgraded throttle body flows.... are these considered sequential fire fuel injection or tuned port? as soon as i get the info i'll run it for ya
my77stang is offline
Old 03-24-2007, 08:07 PM
  #27
my77stang
my77stang's Avatar
96 v6 all stock besides
exhaust ture dual mac gutted cats
and k$n filter
the answer is 3 (i dunno if i could find cam specs and head flow charts.... would be a tough one)
Old 03-24-2007, 08:08 PM
  #28
90Lxstanger
ORIGINAL: my77stang
Heads- what you mentioned- ex bump and port matched(to gt-40 gaskets???or something i was told)
Cam- 266/266 .444/.444 LSA-115
T/B- 65mm
SEFI
  #29
w8less
w8less's Avatar
hahaha my bad didn't even notice that
554 @6000
497 @5500
[IMG]local://upfiles/12612/0C2B392AF25047F2A4F6D2B8C49168D8.jpg[/IMG]
w8less is offline
Old 03-24-2007, 08:09 PM
  #30
w8less
w8less's Avatar
ORIGINAL: my77stang
and k$n filter
my77stang i have a lot of flow charts if u ever want some let me know none for a v6 although
w8less is offline
Quick Reply: Want a Free Dyno Pull?
