Window
Window
I didnt know if this was a common problem or not.............. When I roll up and down my windows it jars and jumps. It drives me crazy, is this a easy fix? Just checking to see if anyone else has this problem. My windows are power.
RE: Window
this has been covered before,but i tried a search and couldn't find it,so here goes take off your door panel, then take your speaker out. There's 3 bolts holding your window motor in. Take the motor out through the speaker hole there is screw holding a cover on the gearbox take it out. You'll find a lotta grease and what's left of 3 nylon or plastic bushings they either have to be replaced or substituted. I used 1/4 in drive sockets cut to fit lengthwise. You could probably use dowel pins from the parts store, and i've heard people use small nuts also. i'tspretty simple to do
RE: Window
ORIGINAL: p1bigun
DreadPirateRoberts
09-26-2015 02:11 PM
mungodrums
09-22-2015 08:36 PM
wishinsky
09-21-2015 09:48 AM
