fuel line fittings
fuel line fittings
i'm pulling my motor and can't figure out how to get the fuelline disconnected from the fuel rail, is there a special trick or tool for this? i have everything else disconnected expect the motor mounts and the a/c and power steering lines,
RE: fuel line fittings
Go to AutoZone and get fuel line fitting tools. It's just a plastic ring that fits around the line. You push it in and you'll hear a click, which means the spring is moved back and the line is ready to separate.
theres no plastic fittings where the fuellinemeats the fuel rail, well not that are visable anyway, and the nearest autozone/ advanced is like 45 miles from here
no, the tool you need is plastic. its a plastic ring that slides over the fuel line. you jam it into the fitting and it separates the lines. any autoparts store will have them
TfcCDR
09-14-2015 12:08 PM
