wideband simulator?
RE: wideband simulator?
Narrow Band simulators are used in order to utilize a wideband O2 sensor IN PLACE OF the stock narrowband O2's.
Using a NB simulator has no advantage in itself.
The advantage comes in being able to datalog (or simply dispay via a gauge), the true AFR.
A NB O2 cannot accurately display AFR.
If you are trying to tune your AFR using the fuel pressure gauge, then save your $$$.
If you have a way to make changes to the .bin, then the WB O2 is well worth the money.
jason
jason
ORIGINAL: 2 kwik
the gauge and wideband unit is useless unless you have a tweecer,pms,etc to make changes...unless you like the cool factor of having some bright red numbers on your dash
idiot
ORIGINAL: cheetha94607
well is there a aftermarket computer that can take plug in wide band. because paying for a wideband and a controller is alot.
It may help us to give you some more specific responses, as everything so far has been pretty general.
Every wide band O2 kit I remember seeing had a narrow band simulator.
The LC-1 (from Innovate)is $200, and has a nb simulator.
jason
