Fuel Pressure adjustment question.
Old 03-26-2007, 10:14 AM
CCF5000
CCF5000's Avatar
Default RE: Fuel Pressure adjustment question.
I'm just looking for something to keep it a little safer until i get it tuned.
CCF5000 is offline
Old 03-26-2007, 10:47 AM
CCF5000
CCF5000's Avatar
my pressure is at like 36 psi currently
CCF5000 is offline
Old 03-26-2007, 11:05 AM
luckythirteen13
luckythirteen13's Avatar
ORIGINAL: Chitown racer
Personally I thinkboosting the fuel pressure much past 40-42 psi to compensate for a lean condition pushes the stock injectors past thier intended duty cycle.
duty cycle is the amount of time the injector is open, not how much fuel the injector flows. there is a reason that fuel regulators will allow as much as 65psi. 42psi is stock, and on a boosted motor, a good rule of thumb is to run 1psi of fuel for each pound of boost. on my motor i run 51psi of fuel. 42psi stock + 9psi boost = 51psi fuel pressure. its to compensate for the pressure inside the manifold that wasnt there before the sc.
anyways, what size fuel pump are you running. after a h/c/i its time for a new fuel pump. the stock one cant flow enough
luckythirteen13 is offline
Old 03-26-2007, 02:46 PM
CCF5000
CCF5000's Avatar
i believe its the stock fuel pump i was thinking about upgrading to a 155 lph does that seem enough? so even though my motor is basically an explorer motor i need more fuel because of the cam and more power? so the adjustable fuel pressure regulator won't do anything for me?
CCF5000 is offline
LiquidDrink
09-29-2015 10:06 AM
foxtrot
09-29-2015 06:32 AM
StalkerGT
09-25-2015 02:41 PM
SteelerNation82
09-16-2015 07:11 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Quick Reply: Fuel Pressure adjustment question.
