March A/C Eliminator bracket - problem, need help!
Old 03-26-2007, 01:43 AM
DonovanM
DonovanM's Avatar
Default March A/C Eliminator bracket - problem, need help!
I just finished installing the March A/C Eliminator bracket (part # 1460). Took a little coaking, but everything finally got hooked up I also bypassed the smog pump. Problem now is, i'm overheating. As far as I can tell, the water pump has plenty of belt to turn it. I've got plenty of coolant. And of course, I don't find this out until 10:30 at night after I've left my mother-in-law's house and everything is already put up.
Any ideas?
BTW, here is the link to the instructions. I used the belt routing on the left. http://www.marchperf.com/instruction...structions.pdf
DonovanM is offline
Old 03-26-2007, 02:33 AM
DonovanM
DonovanM's Avatar
Default RE: March A/C Eliminator bracket - problem, need help!
Anyone have a clue what might be the issue? I was having zero problems before this, so I know it has to do with this relocation. I'm glad I don't work tomorrow...
DonovanM is offline
Old 03-26-2007, 03:35 AM
JZTRK
JZTRK's Avatar
water pump spinning in the wrong direction ??
JZTRK is offline
Old 03-26-2007, 04:13 AM
HC_CrAzYHoRsE
Super Moderator
HC_CrAzYHoRsE's Avatar
belt is probably not tight enough.
HC_CrAzYHoRsE is offline
Old 03-26-2007, 01:34 PM
DonovanM
DonovanM's Avatar
I'll double check it, but when I checked that last night, it seemed OK.
Any other ideas? I need to be up an running by tomorrow...
DonovanM is offline
Old 03-26-2007, 03:55 PM
DonovanM
DonovanM's Avatar
I just adjusted the tension on the belts, and the problem seems to have gone away.
On the bracket there are two pin holes for the tensioner to use, and I put the pin in the one on the right.
DonovanM is offline
Granatelli Sales
01-20-2020 12:34 AM
10-07-2015 07:02 PM
SteelerNation82
09-16-2015 07:11 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: March A/C Eliminator bracket - problem, need help!
