2 coolant temp sensors
On a 5.0L, are there 2 coolant temp sensors that regulate air/fuel ratio and timing?. One is located behind the thermostat housing on the lower intake manifold, and the other is located on the metal heater hose.
RE: 2 coolant temp sensors
ORIGINAL: dimebag
ok thx... after i posted that, i dont think its that... im thinking o2s... but thats enough of my stealin his thread, lol.
ok, so the sensor in the black heater hose (passenger side) is the coolant temp sensor which the ecu uses for a/f ratio and timing and the sensor behind the thermostat, passenger side of the lower intake manifold, is the coolant temp senderfor the temp gauge? I thought the driver's side lower intake manifold side at the very front is the coolant temp sender for the temp gauge?
ORIGINAL: 93LXTealHatch
