rx8
RE: rx8
ORIGINAL: AdderMk2
cavaliers cant go faster than 108mph
they are goverend from the factory... And I doubt he knows about the purple VSS wire trick
RE: rx8
ORIGINAL: tmajikman
I have a dumb question, what does VSS stand for.
ORIGINAL: AdderMk2
RE: rx8
the purple wire off the VSS sends signal to the ECm and at 108mph the internal speed governor kicks in.
if you cut the wire and install a switch, you can break the signal, allowing your car to pass 108mph..
Side Effect: Speedo goes dead!
