is this normal (headers??'s)
RE: is this normal (headers??'s)
smog is off... and bypassed with 76inch belt... this is drivers side only...and it is soo close in there it is hard to determine if lifters/valves or leak.....I am wondering if the clamps that pull the ball and socket together is not sealing completely beacuse the H pipe is stretched and preventing the clamp from tightening more becasue it is touching the bottom of the clamp... ... that make sense?
well here is the link I foundusing the search feature of this forum.... i just dont know what size to use.. there are like 20 options and if 19 will work and 1 wont; I am gonna by fate choose the wrong one..
http://www.drgas.com/store/product.p...t=1&page=1
yes I have heard collector or reducer. Accordinng to that site it is reducer. suppose it depends on who you talk to. I will prolly just take the damn thing off and take into the fargin parts stor of propper fitting...
$10 says it's a leaking manifold. If it were to the h-pipe, you wouldn't be able to distinguish one cylinder firing from another. Did it start when they were installed? If so, you screwed up. If it developed later on, you probably just need to retorque your bolts. You should do that anyway.
well i put headers on a couple months ago and i retorqued them. my car has just about 170,000 miles and its all original.. thats why IM leaning towards lifters or valves
im thinkin my speedo cable maybe bouncin around again too.. brb!
LT you owe me $10[sm=icon_rock.gif] just kidding... I found the problem... Stolemy womans compact mirror and used it toget the angle i needed to see around the header and and saw the steering shaft was in fact touching my headers... so I loosened the motor mount and put a temporary spacer (not quite 1/4 inch and re-tightened... sound is gone from inside the car... well normal engine tick is there outside BUT the inside is quiet again.. Thanks for the help fellas..
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
junior04
09-28-2015 10:53 AM
