Fuel Pressure setting
Old 03-29-2007, 12:24 AM
5pointslow91
5pointslow91's Avatar
Default Fuel Pressure setting
What should i set my FP PSI at with my regulator having the following mods. Full intake and exhaust, pulleys, 24lb injectors, 155 lph fuel pump, and msd ignition.
5pointslow91 is offline
Old 03-29-2007, 12:34 AM
92hatchLX
92hatchLX's Avatar
Default RE: Fuel Pressure setting
42 psi with vacuum disconnected, make sure to reconnect your vacuum line after you're done setting it.
92hatchLX is offline
Old 03-29-2007, 12:37 AM
CCF5000
CCF5000's Avatar
do u plug the vaccum line when its disconnected from the regulator like put ur finger over it?
CCF5000 is offline
Old 03-29-2007, 12:40 AM
LTnone
LTnone's Avatar
Why the massive injectors?
LTnone is offline
Old 03-29-2007, 12:43 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Haha, massive? They're just 24's! Lil overkill for his mods though.
PRO50SC is offline
5pointslow91
im going to be getting heads soon and i just bought the MAF and didnt want to have to get it recalibrated when i switched the injectors
Old 03-29-2007, 12:45 AM
92hatchLX
92hatchLX's Avatar
ORIGINAL: CCF5000
Yeah you can do that, it doesn't make to much of a vacuum leak while it is disconnected.
Old 03-29-2007, 12:52 AM
5pointslow91
alright, thanks 4 the help
Old 03-29-2007, 12:54 AM
92hatchLX
92hatchLX's Avatar
not a problem.
Old 03-29-2007, 01:17 AM
5pointslow91
what is the psi at stock?
Quick Reply: Fuel Pressure setting
