stroking a 302
Old 03-29-2007, 10:31 AM
my77stang
my77stang's Avatar
Default RE: stroking a 302
just an FYI, when you stroke a motor the crank's stroke becomes longer, and to keep the piston from sticking out of the block the wrist pin location is moved closer to the top of the piston...... hence, you will NEED pistons for whatever size stroker application your wanting to build. plus, if you dont buy stuff in a kit you need to make sure its balanced. brand "X" pistons may weigh considerably more or less than brand "Y" pistons.
and yeah, you'll NEED to bore it. when your doing a stock 302 re-ring / bearing job you can get away with not boring if things arent too bad but when you change the crank/rods/pistons the top ring is not going to be stopping before that wear ridge at the top of the cylinder. what happens when your top piston ring smashes into that ridge? your rings go breaky breaky.
my77stang is offline
Old 03-29-2007, 11:26 AM
disturbed471985
disturbed471985's Avatar
with 170k u better bore that stang no reason not to like said above im sure it has ring groves and god knowns whatelse id spend the extra few $$. or u can go the cheap route and leave it alone and hope and pray.
disturbed471985 is offline
Old 03-29-2007, 12:39 PM
88BlueGT
88BlueGT's Avatar
retarted to stroke a motor (or try to) and keep the stock pistons and not clean up the cylinders...... do it right.
88BlueGT is offline
Old 03-29-2007, 04:04 PM
94 G STANG
94 G STANG's Avatar
great info guys ... that clears up any questions... now to plan a different combo lol....
94 G STANG is offline
Old 03-29-2007, 04:12 PM
FullAuto
FullAuto's Avatar
ORIGINAL: my77stang
I'm glad to see someone finally pointed this out. The stroker kit would make a stock piston stick out of the top of the block. Yes, you can have the same bore, but the compression height is different.
Generally, it's better to buy unbalanced unless you're getting the actual balancer and flexplate in the kit (which is rare). I would much rather balance the kit with the actual parts going on your motor. I can sell kits balanced and will if the cusotmer requests it, but I generally try to discourage it. I feel much better when they take it to their local machine shop and have it done with all their own parts.
94 G Stang - Scat 347 kit, new crank, new 4340 rods w/ ARP cap screws, new Probe flattop pistons, rings and bearings = $750.
FullAuto is offline
Old 03-29-2007, 06:03 PM
94 G STANG
94 G STANG's Avatar
thats a damn good deal fullauto i got my eye on it thx......im on a mechanics budget lol
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
69Volunteer
09-30-2015 10:39 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: stroking a 302
