Electric Fan mod, 3.8 taurus
Old 03-30-2007, 10:17 AM
tmajikman
tmajikman's Avatar
Default Electric Fan mod, 3.8 taurus
How much modification is needed to do the modification to get the 3.8l fan to fit my 87 GT.
Thanks
tmajikman is offline
Old 03-30-2007, 03:28 PM
HACKGT350
HACKGT350's Avatar
Default RE: Electric Fan mod, 3.8 taurus
it will slide right in no problem i have one on my 84 i have about an inch between the fan and the water pump pulley and this is with a heavy duty 2 row which is thicker than a 3 row
HACKGT350 is offline
Old 03-31-2007, 02:59 PM
tmajikman
tmajikman's Avatar
Where do I install the electric temp. switch so the fan will turn on automatically, thanks again
Old 03-31-2007, 06:49 PM
new2v8s
new2v8s's Avatar
i actually just did this today and it works great. i mounted my temp switch right beside the battery. the car runs cooler than ever and i also free'd up alil bit of restriction from the clutch fan.so i am pleased with this and i am sure you will be also.
new2v8s is offline
Old 03-31-2007, 07:01 PM
tmajikman
tmajikman's Avatar
ORIGINAL: new2v8s
Does the switch need to screw into the radiator or where the temp switch is for the guage in the car. which fan did you go with, the taurus one. Thanks for the help. btw, I can get a used fan for $45 or a brand new one for $125, what would you do.
Old 03-31-2007, 07:49 PM
FordMustangXBA
FordMustangXBA's Avatar
That's definitely going to be my next mod. I've been wanting to do it for a while. I'll probably just run mine on a switch, though.
FordMustangXBA is offline
Old 03-31-2007, 11:18 PM
CompOrangeHatch
CompOrangeHatch's Avatar
Is this mod that freaking awesome? I have been hearing about it for some time.
CompOrangeHatch is offline
Old 03-31-2007, 11:54 PM
VigCS
VigCS's Avatar
Can you guys post up how you mounted it? I took a crack at mine today but couldn't figure out how to mount the overflow tank and I didn't have the proper materials to fasten the fan itself to the top radiator mounting holes. I had the fan sitting in the clips at the bottom of the radiator, fits well there. This is as far as I got:
Not to thread jack but it'd be beneficial to all...but any suggestions on how to mount it to the top of the radiator? I'm probably just going to get some strips of aluminum to make an extension.
Disclaimer: Zip-tie was used to hold the fan in place, my mechanical fan is back in.
VigCS is offline
Old 03-31-2007, 11:56 PM
HACKGT350
HACKGT350's Avatar
i got my fan for 25 bucks at the junk yard and i think i need a new one i believe the motor is shot on it but i will know for sure tomorrow or monday when i go out and test it
Old 03-31-2007, 11:58 PM
HACKGT350
HACKGT350's Avatar
ORIGINAL: CompOrangeHatch
yeah it made a huge huge huge difference mostly because my fan clutch was frozen and always spinning it was robbing soooooo much from my car. the best thing that ever happend was when it blew to peices and destroyed my radiator lol.
Quick Reply: Electric Fan mod, 3.8 taurus
