1994 5.0 Engine Vibration - Page 2 - MustangForums.com
Old 04-02-2007, 01:11 AM   #11
Mustang1994
Mustang1994's Avatar
Default RE: 1994 5.0 Engine Vibration
Any luck on MaF?
Mustang1994 is offline   Reply With Quote
Old 04-02-2007, 01:36 AM   #12
F5GTS331
the stock balancers are crap on mustangs. id replae it regardless. flywhell could be out of balance too. you would either have to get a new one or take your old one out and have a machine shop turn it. could be the motor mounts too if theres any way you can put a load on the engine sitting still like trying to take off and hold youre brakes and have somebody else looking at the motor to see if it has to much movement in the mount or just look at them if they have real bad cracks on em theyre probably no good. oh andthose balancers do come apart and will kill your timing cover if you wait to long to fix it!!!! youll have an oil leak to hades!!!! as far as the maf bein the problem i would just really have to feel the vibration toknow for sure. my maf went out andabout 3000 rpm it would run like crap kinda like it was missin. well tahts all i got on the issue
F5GTS331 is offline   Reply With Quote
Old 04-02-2007, 02:08 AM   #13
Ninety5five0
+1 on the harmonic balancer
Mine spun a bit on the seal and scraped up my timing cover a lil, but its still good.
Ninety5five0 is offline   Reply With Quote
Old 04-02-2007, 02:15 AM   #14
F5GTS331
mine wore completely through but i thnk most of the damage was done before i bought the car
Old 04-02-2007, 02:46 AM   #15
green95GT
no it comes in on tuesday
green95GT is offline   Reply With Quote
Old 04-03-2007, 11:07 PM   #16
Mustang1994
Ok
Old 04-03-2007, 11:24 PM   #17
seight311
FYI you can take the car to Midas and they will inspect your motor mounts and anything else you request. It's free, how reliable... I dont know depending on the people and location I would guess, but not a bad place to start...
seight311 is offline   Reply With Quote
Old 04-04-2007, 01:36 AM   #18
Mustang1994
Really now for free? I have ta try that
Old 04-04-2007, 04:13 AM   #19
vtecex
i have the same problem on my 95..i replaced the motor mounts with energy suspension mounts and i got a new hb..i dont know what is up with my car:[
vtecex is offline   Reply With Quote
Old 04-04-2007, 06:51 AM   #20
94 G STANG
i dont know who advised you to change maf....and what there reasononing is. maf will not cause a vibration, bad harmonic will vibrate i had a bad maf problem it only made the car sputter and run like crap....i had a bad harmonic before and it had the same symptoms as you described good luck!
94 G STANG is offline   Reply With Quote
2015 Mustang Expansion Tank Granatelli Sales The New S550 2015-2017 Mustang 16 01-30-2017 04:15 PM
2.3 ecoboost dependability mdj89 The New S550 2015-2017 Mustang 2 09-07-2015 12:08 AM
V6 Engine Ticking Nick Oliver V6 S197 General Discussion 2 09-05-2015 11:34 AM
5.0 wont start condition 5.0 kevo 5.0L (1979-1995) Mustang 6 09-03-2015 07:24 PM
Video - 2015 Steeda Mustang Product Testing (Prototype Suspension Parts) tj@steeda Steeda Autosports 0 09-01-2015 09:16 PM
1994, 1995, 50, 94, bad, cobra, engine, ford, gt, motor, mustang, revving, shake, shifter, vibration, vibrations
