WTF @ BBK.
Old 04-01-2007, 12:26 AM
kcsoa22
kcsoa22's Avatar
Default RE: WTF @ BBK.
My underdrives came with allen heads too. Plus 3 on the allen heads!
kcsoa22 is offline
Old 04-01-2007, 12:37 AM
whiteout 5.0
whiteout 5.0's Avatar
yea? i had the same problem. so i went out to the store and got allen key ones. then i STILL COULDNT GET IT ON cause the pocket everyday allen set that flips open wont give you enough space to tighten them down you need one with a long shank. i got the hex heads on there i put the bolts on the socket and threaded them in sideways and they walked themselves in straight and somehow didnt slip off i guess i got lucky.
whiteout 5.0 is offline
Old 04-01-2007, 12:42 AM
ZachW04Stang
ZachW04Stang's Avatar
My underdrive pulley came with allen head bolts. Made things 10 times more easier since I tried putting the stock bolts in at first.
ZachW04Stang is offline
Old 04-01-2007, 12:53 AM
5.0stanger
5.0stanger's Avatar
They come with socket head cap screws for that reason, too tight to fit a normal hex head bolt.
5.0stanger is offline
Old 04-01-2007, 01:19 AM
my77stang
my77stang's Avatar
see how smart i am? hell i dont even have UDP and i knew this answer before anyone else[8D][8D][8D][8D][8D]
my77stang is offline
Old 04-01-2007, 01:24 AM
Li0nHart
Li0nHart's Avatar
55 ft/lbs is nothing a decent socket can't handle....you could always replace the bolts with allen or torx heads.
Li0nHart is offline
Old 04-01-2007, 01:33 AM
VigCS
VigCS's Avatar
ORIGINAL: PRO50SC
Are those the bolts that came w/ the pullies. Plus 1 on the allen heads!!
No, they're the bolts that were on the stock pulley. I honestly don't know what they came with....I was digging through my box of parts and said "Woah..UDPS!". Didn't even know I had them, no bolts included, though.
VigCS is offline
Old 04-01-2007, 01:34 AM
my77stang
my77stang's Avatar
time to go to ace hardware, just make sure the bolts you get are HARD
Old 04-01-2007, 01:38 AM
jslove1408
jslove1408's Avatar
I use a thinwall socket everyday at work to torque down lugnuts mainly to 100ft/lbs. with no problem.
jslove1408 is offline
Old 04-01-2007, 02:49 AM
LTnone
LTnone's Avatar
I had to delay my project overnight because of those stupid things too[:@] I got the allens
LTnone is offline
Quick Reply: WTF @ BBK.
