WTF @ BBK.
Old 03-31-2007, 07:46 PM
VigCS
VigCS's Avatar
Default WTF @ BBK.
Do they always make their underdrive crank pulleys so small that you can't get a socket over the bolt to tighten it?
VigCS is offline
Old 03-31-2007, 07:48 PM
FordMustangXBA
FordMustangXBA's Avatar
Default RE: WTF @ BBK.
Of course, they probably saved .001 cents per unit by doing it that way.
FordMustangXBA is offline
Old 03-31-2007, 07:51 PM
VigCS
VigCS's Avatar
And kept my from putting it on today!!
VigCS is offline
Old 03-31-2007, 07:54 PM
frdmstng1986GT
frdmstng1986GT's Avatar
go and get youreself a deep well thin wall socket. should work for you then.
frdmstng1986GT is offline
Old 03-31-2007, 07:58 PM
VigCS
VigCS's Avatar
ORIGINAL: frdmstng1986GT
There's such thing as a thinwall socket? I would think if there is it wouldn't be able to hold up to the 55 ft lbs I torque my crank bolts to.
VigCS is offline
Old 03-31-2007, 08:00 PM
varad745
varad745's Avatar
I've used a lathe or belt sander to grind down an old socket to use for tight fits like this and it worked well. I do not know if it will hold up though having to really tighten down the crank bolts.
varad745 is offline
Old 03-31-2007, 08:05 PM
my77stang
my77stang's Avatar
can you get some allen head bolts? that should fix ya right up. using a allen socket you should be able to get it more than tight enough... and it'll be trick yo!
my77stang is offline
Old 03-31-2007, 08:08 PM
frdmstng1986GT
ORIGINAL: VigCS
yes there is such a thing. they carry them at sears. and yes they will hold up to the 55ft/lbs.i have used them before to put lugbolts on a 911 carreara(sp?) cause there was so little room between the bolt head and wheels. they were torqued to 95ft/lbs.
Old 04-01-2007, 12:19 AM
PJB
PJB's Avatar
My Proforms came with allen head bolts because the bolts are so close to the pulley.
PJB is offline
Old 04-01-2007, 12:23 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Are those the bolts that came w/ the pullies. Plus 1 on the allen heads!!
PRO50SC is offline
Quick Reply: WTF @ BBK.
