AOD gears?
RE: AOD gears?
ORIGINAL: 91RedHatchback
3.73 IT IS GUYS! ! ! Thanks alot.
i'd check your door tag first, if you have 3.27's you'll hardly notice it and unless your on wet pavement it won't break them loose. (ax code = "e") z=3.08, m=2.73
i've had 2 aod cars, i don't like 3.73's in 5-speeds and the 1st gear is overwhlmingly huger on a 5-speed.
3.35 compared to a 2.40, multiply that by rear gear and you see that a aod needs 4.10's to equal a 5-speed w/ 3.08's
will it be better ??? yes
but an ethiopian chewing on a rotten cracker is better than dirt so thats hardly an argument (i know some hard core aod will guy will try it)
i have daily driven 2 stangs now w/ 4.10's and 2 w/ 3.73's
4.10's will get you 21 mpg if your cool
RE: AOD gears?
The thing is that im a college student and its my means of transportation most of the time...sometimes I use my mothers 6 cylinder stang. but for the most part I like driving mine. Im gonna check the side of my door to see what I have like nitrous bob said and then debate on 3.73 or 4.10s cause if i have3.27s I may go 4.10.
RE: AOD gears?
RE: AOD gears?
I checked the AX Code and I have an "m" soIcurrentlyhave 2.73 gears according to nitrous bob.thats making me want some 3.73's some more than 4.10's, lol undecisive. in the end when i order them its a 60% that ill go with the 4.10's anyway.... thanks for all of your help andinput guys!
RE: AOD gears?
you cant fairly compare the manual's and auto's internal gear ratios. its apples and oranges. the auto has the ability to do a thing called "torque multiplication". im not tryin to b a smart @ss or persuade him to go with a certain gear or anything, just throwin it out there
RE: AOD gears?
I went w/ 3.90's for my 93 GT BUT the only reason I did that was because I plan on boosting in the future. If I didnt plan on boosting there no doubt in my mind I would have 4.10's or 4.30's in a heartbeat. The 3.90's are nice but for NA I would of went bigger. Highway driving it what you need to consider though... I never highway drive in my car. I see like 2,400 at 65-70w/ my 3.90's. Also, I went from 2.73's to 3.90's and did not see a drop in gas mileage at all........ NOTHING. And the gas mileage difference between 3.73's to 4.10's is very minimal.
