Spilling Coolant
Old 04-01-2007, 11:28 PM
ckyguy68
ckyguy68's Avatar
Default Spilling Coolant
Im not overheating according to my temp gauge, but whenever im idling or shut the car off, the radiator sprays out coolant. I dont have an overflow tank, so it just drip onto the ground. Its making a mess in my driveway and im sick of having to add coolant. I have an electric fan and i recently changed the t stat. Even when i fill the car up with coolant and let it idle with the cap off to burp it, it still just randomly spills a bunch of coolant out, then the level just drops. It will keep doing that for a while whentrying to burp it. I also recently installed a new water pump so i am just frustrated and am running out of ideas. Any help is appreciated.
ckyguy68 is offline
Old 04-01-2007, 11:31 PM
HACKGT350
HACKGT350's Avatar
Default RE: Spilling Coolant
get an over flow if you have to get a soda bottle for now see what happens. where is it coming out of the radiator cause you might need a new one
HACKGT350 is offline
Old 04-01-2007, 11:50 PM
mattdel
mattdel's Avatar
thats supposed to happen when u burp, it comes up a bit, then sucks in. thats when u refill and cap. done.
mattdel is offline
ckyguy68
ckyguy68's Avatar
Im sorry i forgot to note that its spilling out of the overflow line. This means im exceeding the radiator cap's pressure, correct? Maybe i need a new radiator cap?
ORIGINAL: HACKGT350
ckyguy68 is offline
Old 04-01-2007, 11:54 PM
ckyguy68
ckyguy68's Avatar
Can youexplain why is pisses out coolant while driving?
ORIGINAL: mattdel
ckyguy68 is offline
Old 04-02-2007, 12:20 AM
thunderjet429
thunderjet429's Avatar
that is why there is a cold and hot mark on a overflow.... it fills when engine is operating temp and goes back in the radiator when it cools... elementary watson.
thunderjet429 is offline
Old 04-02-2007, 12:22 AM
HACKGT350
HACKGT350's Avatar
thats why i said get a soda bottle till you get a new overflow
Old 04-02-2007, 12:51 AM
ckyguy68
ckyguy68's Avatar
I still don't understand why my radiator cap hisses after i shut the car off... This has only been happening recently.
ckyguy68 is offline
Old 04-02-2007, 12:54 AM
91stang
91stang's Avatar
ORIGINAL: mattdel
sorry to steal this thread but i just put in new fluid and i need to burp it. so you just jack up the front and crank it with the radiator cap off?
91stang is offline
Old 04-02-2007, 01:06 AM
5.0stanger
5.0stanger's Avatar
Well, it is normal for coolant to come out of the radialtor, hence the PSI rated radiator cap, that is the purpose of the overflow, but an excessive amoutof pressure will make it spit out more than normal causing you to have a lower than normal coolant level. The extra pressure can be caused be a few things, simplest would be a bad cap(simulating extra pressure by opening too soon) or stat not functioning properly allowing the coolant to heat/expand more, or a blown head gasket(which I experienced) that blows compression past the gasket into your coolant causing extra pressure.
I would begin by adding an overflow, it should level out because it can only expand so much under normal conditions, meaning you shouldn't keep losing coolant if you get it just right. If you keep filling your overflow(which I did with my blown headgasket, overfilled it all over the motor[>:])there is a problem. I would also add a new cap. If your problem keep up, it may mean somethingworse.
5.0stanger is offline
Quick Reply: Spilling Coolant
