Anyone have a complete Trick Flow TW setup? Or just a question about it...
I've got a BONE stock 1990 GT mustang, 5.0l. I want to do intake, heads, cam, lt's, nitrous and suspension here in the next month. I've got about $4000 or so to spend.
I like the Trick Flow packages, and I think I want the Track Heat setup. This is a street car w/ strip duties, no really daily driving, just cruising, street fun and occasional track days.
If I were to get this "kit", does anyone have any dyno numbers from this setup?
http://www.mustangsunlimited.com/ite...=TFS350370B+01
It sounds like a really nice setup. A set of long tubes and duals, as well as a 100 shot should do very nice in the car.
What throttle body and Mafs/injectors would you guys recommend for this setup?
Here's an idea, 73mm mafs and 19lb or 24lb injectors, which size do I need?
http://www.mustangsunlimited.com/ite...asp?T1=CL19+01
And a 75mm TB would make sense right? Since the mafs is 73mm...
http://www.mustangsunlimited.com/ite...?T1=BBK1503+01
Or should I go with a 70mm TB?
Anything wrong with the Trick flow stuff?
I'd also get a new clutch/flywheel, and gears, maybe 3:73's?
Thanks guys!
Thanks guys!
RE: Anyone have a complete Trick Flow TW setup? Or just a question about it...
there was just some info on here the other day of how he had just came back from the dyno with some numbers he had the trickflow top end kit on a mustang dyno he made 290 to the wheels. i cant find it in search
ORIGINAL: jtmustang
Mod list:
Rebuilt 306 w/stock rods and crank
10:1 TFS specific pistons
TFS TW Heads
TFS Stage 1 cam
1.7rr's
GT-40 Intake with 3/8 spacer
BBK FPR
BBK 190lph fuel pump
24# injectors with fenderwell CAI ,76mm C&L meter, and tru-flow pipe
70mm T-body and EGR (BBK)
MSD TFI coil
Underdrive pullies
BBK ceramic shorties
BBK catless X-pipe
2.5" Flowmaster catback
G-Force T-5
Mcleod clutch w/ king cobra pressure plate
True-Trac posi and 3.55 gears
Flex-a-lite electric fan
I think that's it for HP modifying things. Hope this is in depth enough for you guys.
< Message edited by Scout2232 -- 3/29/2007 12:32:31 AM >
those were what he listed
TFS TW Heads
TFS Stage 1 cam
1.7rr's
BBK FPR
MSD TFI coil
Underdrive pullies
BBK catless X-pipe
G-Force T-5
im at 340 rwhp and thats with the holly systemax 2. you better be thinking about good mods to back up the motor because without suspension and such your screwed. heres a video below of me running a 200 model cobra with trickflow intake and cai just gives u an idea.
heres the vid http://www.youtube.com/watch?v=EXo4lVykv9M
what heads/cam do you have in that 306 iceman? god knows you don't put down 340whp with just the systemax2 intakes. Or is your car carb'd and you've got the kit? More info please.
I'm planning on a suspension setup, probably the strange 10way kit from summit, and control arms.
