engine removal trouble
ive removed every bolt i can find, took out the starter, removed the clutch cable, disconnected everything but when i try to slide the engine forward it doesnt budge. anyone have any idea on what i forgot to do or whats wrong?
RE: engine removal trouble
There are also two bolts at the very base of the transmission that are smaller than the rest. They're easy to miss. The motor mounts aren't immediately obvious either. They point upward into the block and can't be seen from above.
One thing I did that helped everything come loose was raise the transmission with a jack. After that, it was simply a matter of hoisting the engine up just a little until I could slide it foreward away from the trans.
im not pulling the tranny too. i know i should have but i figured that out today when i already unbolted everything. i think at the stage i am now it would be easier to finish unhooking the transmission. i just want to make sure i dont screw anything up. i was told there is a plate on the transmission usually where the inspection sticker is and once thats off you can unbolt the clutch and the pressure plate. is this true? what else do i need to unbolt
the pressure plate bolts to the flywheel but that should come out with the motor. are you up above the motor mounts? by jacking up and getting above the mounts are you binding up the tranny to motor making it stick?
ORIGINAL: five0fm
the whole bellhousing came with the motor. is that bad?
