Do I need to upgrade my fuel rails??
THIS IS THE LAST THING I NEED BEFORE IT GOES ON THE ROAD!!
I have a 302 W/ Edelbrock upper and lower intake, stock heads, E-cam, 36lb injectors, 80mm mass air, 70 mm throttle body and a chip. I am running this set up w/ a P1SC procharger intercooled supercharger with 8-to 10psi boost. I upgraded the fuel pump to a 255 lph, will my stock fuel railssupply enough fuel for this setup? I don't wanna run to lean, if not do you know what size fuel railsi will need so i don't run to rich? thanks for all the help
foxtrot
09-29-2015 06:32 AM
09-17-2015 07:57 PM
zanemoseley
09-06-2015 12:58 PM
