check engine
Old 04-05-2007, 02:56 AM
91ford302
91ford302's Avatar
Default check engine
i know the check engine light can mean a ton of things and i know my car is OBD 1 so like noone can hook up to it, so how am i supposed to know what the check engine light is coming on for? It just started tonight as i came home from work. every time it upshifted (AOD) the light came on for a second, then went back off as the rpms went up. I was wondering if anyone else has had this same thing happen and knows what it might be, or how i can figure it out myself. I know some cars you can use a jumper wire or mopar you can turn the key 3 times, but havnt heard a trick like that for fords.
the only thing i could think it was right now is like a rich or lean reading because its just shifting so the engine is a low rpms in a higher gear and maybe the car is compensating enough. I also know i need to replace the fuel filter, so i was thinking it may be a fuel related problem. Any help is appreciated.
91ford302 is offline
Old 04-05-2007, 02:54 PM
91ford302
91ford302's Avatar
Default RE: check engine
bump. [&:]
Old 04-05-2007, 02:58 PM
Joel5.0
Joel5.0's Avatar
All you need is a test light, VOM or use the CEL to count the codes....... TroubleCodes.net- engine & OBD2 Trouble Codes and Technical info & Tool Store.
Joel5.0 is offline
Old 04-05-2007, 05:56 PM
Stanpower
Stanpower's Avatar
maybe a bad 02 sensor? check engine codes on computer.......Good Luck!
Stanpower is offline
Old 04-05-2007, 07:06 PM
91ford302
91ford302's Avatar
ok i looked at that site on the whole checking engine codes, but i can make sense of it. it doesnt say anything about the 5.0, nor does it say where this hand drawn connector is located. a little better explanation would be appreciated. thanks.
Old 04-05-2007, 09:33 PM
95ssn95
95ssn95's Avatar
the connector on your car "should" be under the hood,drivers side between firewall and the strut tower and u can get an obd 1 tester for cheap from auto zone or any other parts store....
95ssn95 is offline
Old 04-05-2007, 09:42 PM
p1bigun
p1bigun's Avatar
autozone will pull your codes then walk back pick up a haynes book and write down what it is or you could post them here and someone will to=ell you what they are
p1bigun is offline
Old 04-05-2007, 09:44 PM
mattdel
mattdel's Avatar
sigh... autozone doesn't sell anything capable nor do they test OBD 1
mattdel is offline
Old 04-06-2007, 12:31 AM
91ford302
91ford302's Avatar
yeah OBD 1 is outdated, and i know autozone does not check it. I will try to find the connector and pull my codes this weekend and see whats up. thanks.
Old 04-06-2007, 12:41 AM
onebad88
onebad88's Avatar
autozone does have an OBD 1 tester, its $30 or you can buy the one that is for OBD I and II for 379.00
onebad88 is offline
djbigskrilla
09-20-2022 01:04 AM
ChampInSD
10-02-2015 04:55 AM
J.casone400
08-28-2015 09:33 PM
labudski
08-24-2015 07:23 AM
mweiland
08-13-2015 05:11 PM
Quick Reply: check engine
