Torque box
RE: Torque box
ORIGINAL: JOEZDRACO
Before i weld on my subframe shouldI run a weld around the torque box seems? The factory spot weld are what i am talking about. Then weld in the torque box adapter then subframe?
RE: Torque box
holy hell
ORIGINAL: 5literchevyeater
i did this with a stock motor3.73 and et streets never question getting reinforcements for a second just do it is well worth not having to go through the trouble of finding a roller or another car for 75 bucks
RE: Torque box
ORIGINAL: luckythirteen13
i did some welding on the seams for my toque boxes and i also installed the battle box kit and then tied the kit into my roll cage
RE: Torque box
ORIGINAL: Blue Oval
did you run the tubes to the upper or lower plates? do you have pics that show it
here is the upper
i dont have a picture of the lowers i ran a short tube from the plate that mounts inside the car to the main hoop......not to hard to visualize. the plate im talking about sits under the rear seat or in my case, where the rear seat used to be
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
