too rich...e303..too broke to guess
Old 04-05-2007, 10:14 PM
porkichu
porkichu's Avatar
Default too rich...e303..too broke to guess
89lx e303 summit rebuild kit.20k on motor 170k on everything else.i'm getting codes 15,22, and 67.She runs rich as hell and its worse in warmer weather.Should i get anew computer first or EGR or MAF.....Maybe MAP.please help,i spent it all on the rebuild
porkichu is offline
Old 04-05-2007, 10:27 PM
F250sd
F250sd's Avatar
Default RE: too rich...e303..too broke to guess
What about looking at the coolant temperature sending unit?A faulty one will make you car run rich.Shouldn't be all that expensive.
F250sd is offline
Old 04-05-2007, 10:46 PM
92hatchLX
92hatchLX's Avatar
It's going to run rich until it is tuned. Let the computer adjust to it for a while and it should get better.
92hatchLX is offline
Old 04-06-2007, 10:05 PM
namor1235
namor1235's Avatar
my MP3 player has more technology then that. computer ur problem will continue.
i dont remember now if u fix the small code first or the big code first. ill get back to u
namor1235 is offline
Old 04-06-2007, 10:58 PM
backfire2007
backfire2007's Avatar
what the hell do thosecodes mean? 15,22,154, WTF
backfire2007 is offline
Old 04-06-2007, 11:10 PM
tmajikman
tmajikman's Avatar
Try this link here: http://autorepair.about.com/cs/troub...l_dtcs_37a.htm
tmajikman is offline
Old 04-06-2007, 11:13 PM
92hatchLX
92hatchLX's Avatar
Second thought, I just looked up the codes. You were right, you need an ECT (code 22), code 66 has something to do with your A/C not working or it is unplugged.
Old 04-06-2007, 11:21 PM
tmajikman
tmajikman's Avatar
I hope I got you the correct link, I have a book at my office of all the codes, let me know what you need or if that link helped you out.
Old 04-06-2007, 11:24 PM
92hatchLX
92hatchLX's Avatar
I've got the code book in my hand. Were those codes for KOER or KOEO? I can put some exact definitions on here if I know which codes those were for.
Old 04-06-2007, 11:40 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: backfire2007
15 - Readout Memory Test Failed (O)
22 - Manifold Absolute Pressure/Barometric Pressure Sensor Out Of Self Test Range (O,CM,R)
1 = separator
54 - Intake Air Temperature/Air Charge Temperature Circuit Open (CM,O,R)
Clear codes (disconnect battery for 5-8 minutes) and repeat the test, since code 54 didn't show up as a O(=On Demand) code, it's not a "hard failure" code.
If code 22 repeats as an O code, MAP/BP sensor might need replacement.....or the connector needs repair, or the wiring.....need to check.
Joel5.0 is offline
lincolnshibuya
12-08-2015 04:37 PM
BeatnikFink
10-01-2015 08:00 PM
UrS4
09-30-2015 10:13 AM
Drastang
09-30-2015 03:48 AM
stangin1996gt
09-21-2015 11:01 AM
Quick Reply: too rich...e303..too broke to guess
