Fuel smell
Old 04-06-2007, 09:41 PM
92hatchLX
92hatchLX's Avatar
Default RE: Fuel smell
I run no cats and I've got the TFS 1 cam, it smells horrible of gas/exhaust fumes.
92hatchLX is offline
Old 04-06-2007, 09:42 PM
mattdel
mattdel's Avatar
my car doesn't smell at all. no cats.
i had a fuel smell before i replaced my tank. i didnt find any leaks in the tank, but who knows. maybe the seal for the sending unit or pump was no good. smelling gas doesn't necessarily mean your leaking. there's lots of vent hoses and whatnot.
mattdel is offline
Old 04-06-2007, 09:46 PM
Arrid Extra Dry
Arrid Extra Dry's Avatar
prolly comming from under the hood somewhere, if its that strong.
Arrid Extra Dry is offline
Old 04-06-2007, 09:51 PM
OPIATE5.0
OPIATE5.0's Avatar
Its not quite as strong as I may have lead on, it doesn't make my eyes water or anything just a noticable odor... My buddy that sold the car to me said that the pump would have to be changed when I bought it, but i'm trying to hold off for that horrible chore... I know it needs to be done but, there is really no easy way to do it...
OPIATE5.0 is offline
Old 04-06-2007, 09:55 PM
samseed101
samseed101's Avatar
If it's not that strong but noticable, then check your A/F ratio and check your O2 sensors (which can also screw up your ratio.)
samseed101 is offline
Old 04-06-2007, 10:03 PM
OPIATE5.0
OPIATE5.0's Avatar
Would that effect the engine performance as well?
Old 04-06-2007, 10:04 PM
91lxstang
91lxstang's Avatar
yes because its not gettin the right amount of fuel
91lxstang is offline
Old 04-06-2007, 10:07 PM
samseed101
samseed101's Avatar
Well if you were running too rich it could cost you power. But if you run too lean it could cost you your engine. The trick is to get it just right
While you're under the hood playing and looking around, might as well advance your timing a few degrees to take advantage of some free HP and TQ. I know it's unrelated to this problem, but it's fairly quick and easy to do and if you are looking for performance (judging by your last question, you are.) then it's a great free mod.
Old 04-06-2007, 10:08 PM
OPIATE5.0
OPIATE5.0's Avatar
I just hate messing with the timing...
bradleyb
11-27-2015 07:50 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel smell
