5.0 HO speed density cams
Old 04-08-2007, 08:20 PM
rasmith1
rasmith1's Avatar
Default 5.0 HO speed density cams
does anyone know how big of a cam i can run with a speed density setup..Thanks
rasmith1 is offline
Old 04-08-2007, 08:25 PM
frdmstng1986GT
frdmstng1986GT's Avatar
Default RE: 5.0 HO speed density cams
ORIGINAL: rasmith1
https://mustangforums.com/m_2170036/...tm.htm#2170036
frdmstng1986GT is offline
Old 04-08-2007, 08:39 PM
AdderMk2
Banned
AdderMk2's Avatar
its weird, the things people will find if they look in the stickies
AdderMk2 is offline
Old 04-08-2007, 09:36 PM
ZachW04Stang
ZachW04Stang's Avatar
I'm going to be installing a cam in my speed density car this week. Its about the most agressive you can go with speed density. I'mgot this cam here. I'll definitly post up how the car runs.
ZachW04Stang is offline
Old 04-08-2007, 09:57 PM
ZachW04Stang
Also check out this chart: All the colored cams work with speed density except the bottom one.
Old 04-08-2007, 10:06 PM
AdderMk2
Banned
AdderMk2's Avatar
Zach, if you have a really bad lope issue due to fuel, try installing a small inline fuel filter in the vac line to the MAP sensor... its an old megasquirt trick, but it works for ford SD too
AdderMk2 is offline
Old 04-08-2007, 10:12 PM
rasmith1
rasmith1's Avatar
I am looking for one that will give me a good sound I am running the motor in a 1932 ford coupe..
rasmith1 is offline
Old 04-08-2007, 10:39 PM
ZachW04Stang
ORIGINAL: AdderMk2
Tom moss told me to do something very similar to keep vacuum pulses to the map down.
Rasmith I'd look into a mass air swap if your looking for sound. SD cars with cams aren't really going to idle to well under 1000rpm. You might have a slight lope but nothing to noticable.
Old 02-19-2008, 07:28 PM
pimpinstang1
pimpinstang1's Avatar
i want to keep my sd setup aslo but i want a lopy cam
pimpinstang1 is offline
Old 02-19-2008, 08:52 PM
dimebag
dimebag's Avatar
jesus christ... no more bumping threads. post in the SD section
dimebag is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
vintageaion
09-08-2015 10:45 AM
Quick Reply: 5.0 HO speed density cams
