Stock Valve Covers and a Cam
Old 04-12-2007, 01:13 AM
ZachW04Stang
ZachW04Stang's Avatar
Default Stock Valve Covers and a Cam
Alright guys I did 50% of my cam swap tonight. I'm putting everything back together and I'm wondering if onceI adjust the rockers if there going to touch the valve cover from the extra lift. The cam has .512 lift with my 1.6 rockers. Anything to worry about? It would be a good excuse for me to order a set of trickflow valve covers but right now I'd rather put the money else where.
ZachW04Stang is offline
Old 04-12-2007, 01:16 AM
92hatchLX
92hatchLX's Avatar
Default RE: Stock Valve Covers and a Cam
I've got .499/.510 lift and my stock valve covers are fine.
92hatchLX is offline
Old 04-12-2007, 01:18 AM
ZachW04Stang
Do you have stock rockers or did you upgrade to rollers rockers? I was going to leave the stock ones for now since I hope to get rid of these stock heads really soon. Within a month or 2.
Old 04-12-2007, 01:19 AM
LTnone
LTnone's Avatar
If nothing else just put em on and turn the engine over by the crank bolt a few times. You'd hear it. You have upgraded valvesprings?
LTnone is offline
Old 04-12-2007, 01:21 AM
92hatchLX
92hatchLX's Avatar
You should be fine with the 1.6RR's, I beleive that the stock (stamped) rocker arms are 1.6:1 also. If you were running 1.7:1 rocker arms you'll run into problems with the stock valve covers.
Old 04-12-2007, 01:23 AM
ZachW04Stang
ORIGINAL: LTnone
I'm just swapping the cam right now. I'm hoping to get a set of heads in the near future. The cam is pretty mild, .512/.512 lift and 218/224 duration at .050. Its power band is only good till 5400 or so and I don't plan on going past 5200.
Old 04-12-2007, 03:24 AM
frdmstng1986GT
frdmstng1986GT's Avatar
ORIGINAL: 92hatchLX
You should be fine with the 1.6RR's, I beleive that the stock (stamped) rocker arms are 1.59:1 also. If you were running 1.7:1 rocker arms you'll run into problems with the stock valve covers.
close.. but i fixed it for ya... got to be specific around here.
frdmstng1986GT is offline
Granatelli Sales
01-20-2020 12:34 AM
mirandaandjimmy
11-16-2015 08:51 AM
YoungStangsMan
09-05-2015 07:01 PM
iculookin
09-02-2015 12:34 PM
09-01-2015 08:16 PM
Quick Reply: Stock Valve Covers and a Cam
