Shifter rattle
Old 04-22-2007, 12:55 AM
  #21
sm6989
sm6989's Avatar
Default RE: Shifter rattle
all checked out well..
sm6989 is offline
Old 04-22-2007, 11:02 PM
  #22
stang8689
stang8689's Avatar
my shifter use to shake. after installing a polyurethane tranny mount it stopped
stang8689 is offline
Old 08-01-2007, 01:26 PM
  #23
92FOX
92FOX's Avatar
ORIGINAL: stang8689
How much did a polyurethane tranny mont cost ,? I have the same problem shaking at HIGH RPM'S ?
92FOX is offline
Old 08-01-2007, 01:42 PM
  #24
steele901
steele901's Avatar
check your driveshaft. after i put in my new tranny the 4 bolts in the back worked their way loose. shifter started shaking really bad at higher speeds and rpms
steele901 is offline
Old 08-01-2007, 02:50 PM
  #25
WhiteWindsor
WhiteWindsor's Avatar
Grab the back of your driveshaft, if it has much play then it is probably your pinion gear (need to tighten pinion bolt). My other fox did the same as yours, my shifter would vibrate violently. It turns out that i needed to tighten my pinion bolt and replace my inner tie rods. Not really sure which one was causing prob. because it did both at same time. To check you tie rods jack front of car and grab your wheels @ 9 and 3 and see how much play you have, a little is too much. But after doing both of these, the car drove 10000% better.
WhiteWindsor is offline
Old 08-01-2007, 07:31 PM
  #26
92FOX
92FOX's Avatar
I Have the same problem, Im pully my hair out and dont know what to do ?
Car shakes really bad at high RPM's just started a week ago...
and lost power and shifter shakes as well.
[/align]
92FOX is offline
Old 08-01-2007, 09:04 PM
  #27
stang8689
stang8689's Avatar
Like $25, cheap. I also have aluminum driveshaft which is new. My shifter alaways shook until the polyurethane bushing.
firehorse02
11-16-2015 11:28 AM
Explosive
10-02-2015 07:45 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Shifter rattle
