AOD Trans won't shift - MustangForums.com
Old 04-16-2007, 01:03 PM   #1
Montys91
Default AOD Trans won't shift
My AOD trans won't shift out of first!! I'll put it in Overdrive and drive but it won't shift. If I get up to about 25-30 then it will just rev up as if it is in nuetral until it hits a high RPM then grab as if it's still in first gear. The trans was just rebuilt about 2 years ago. And for the smart asses like Adder...yes I checked the fluid. It's good and doesn't smell burnt.
Could a bad filter cause this??! I'm hoping it's something simple, but with my luck it won't be.
Montys91 is offline   Reply With Quote
Old 04-16-2007, 07:56 PM   #2
94IVGT
Default RE: AOD Trans won't shift
the problem sounds like a speed sensor on the trans. check your connectors for corrosion, and check for a broken wire.
94IVGT is offline   Reply With Quote
Old 04-16-2007, 07:57 PM   #3
94IVGT
by the way whats the year and engine size
Old 04-16-2007, 08:01 PM   #4
P Zero
P Zero's Avatar
AOD's have throttle valves. They MUST be adjusted appropriately in order for the AOD to shift. (This does NOT apply to the AOD-E). There should be a throttle valve cable attached at the TB or carb. It too tight, you gotta pop the locking clip out and adjust it. Ill see if I can find some info for you.
-P.
P Zero is offline   Reply With Quote
Old 04-16-2007, 08:20 PM   #5
93 LX FiveO
93 LX FiveO's Avatar
there is no such thing as a "perfect working AOD"
93 LX FiveO is offline   Reply With Quote
Old 04-16-2007, 08:38 PM   #6
P Zero
P Zero's Avatar
Ok I found the article on another forum I go to.
http://www.rangerpowersports.com/for...d.php?t=137652
This will tell you what and how to adjust in order to get your AOD shifting. Hope this helps.
-P.
PS: Id like to thank www.rangerpowersports.com for this article.
Old 04-16-2007, 08:44 PM   #7
86 GT 5.0
Quote:
ORIGINAL: 93 LX FiveO
Mine works fine with no problems... But has been rebuilt..
86 GT 5.0 is offline   Reply With Quote
Old 04-16-2007, 09:59 PM   #8
Montys91
Thanks for all your help guys, I'll try out some of your ideas and get back to you.
Old 04-16-2007, 10:07 PM   #9
Montys91
I almost forgot, it's a 91, 302 freshly rebuilt.
Old 04-16-2007, 10:29 PM   #10
Montys91
I tried a few things and heres what I figured out...
It's shifts hard in to rev. and drive
If I'm going down the road, let off the gas and shift it back and forth from "N" to "D" about 10 times then back into "OD" it will shift. Almost like the cable is sticking and moving it back and forth frees it up somehow.
Theres a couple of things for you guys to kick around...by the way, if anyone is interested, it just came up on the market. Just found out we have a new baby on the way and it's time to let someone that has the money fix it up.
Possible Clutch Issues..? Thunderball 4.6L (1996-2004 Modular) Mustang 15 11-23-2015 12:49 AM
Street Action Tonight Explosive Street/Strip 17 10-02-2015 08:45 AM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 05:55 AM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 06:54 PM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 11:49 AM
1st, 3000, 96, aod, ford, gear, hard, mustang, problems, reverse, rpm, shift, shifting, shifts, trans, wont
