How to Prime the Oil
Old 04-25-2007, 12:08 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
Default How to Prime the Oil
I am in day 3 of my H/C/I...making some nice progress
I was wondering when I am complete, how should I get the oil up to the new heads...
From what I know already, pull my plugs and turn the crankshaft about 20-times...reinstall the plugs, and start her up.
Sound correct?
CantStopTheFox... is offline
Old 04-25-2007, 12:13 AM
LX 90
LX 90's Avatar
Default RE: How to Prime the Oil
When i did mine we made the crank turn the engine untill there was oil coming through all the rockers. Of course the plugs were off, so it was just crankin.
LX 90 is offline
Old 04-25-2007, 12:19 AM
CantStopTheFox...
How did you get it to turn? You just hit the crank with a ratchet??
Old 04-25-2007, 12:23 AM
Ninety5five0
Ninety5five0's Avatar
Get an old dizzy and take off the gear and sping the oil pump with a drill. They also make a oil pump priming tool. You can also just unplug the coil and crank the car over.
Ninety5five0 is offline
Old 04-25-2007, 12:25 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: CantStopTheFox...
Sound correct?
that is by far the WORST thing you can do....
go to your local part store and rent an oil pump priming rod...
AdderMk2 is offline
Old 04-25-2007, 01:12 AM
irish1
irish1's Avatar
+1 on the old distributor...did that today, knocked the gear off, knocked out a few pins and presto, one free priming tool, chucked it in my cordless, set it to reverse and after about 10 seconds I had oil pressure. Don't get crazy with high speed on a 24 volt drill or anything nut when the pump primes and starts pumping, I could feel the drill start to work harder...hope that helps.
irish1 is offline
Old 04-25-2007, 01:26 AM
F5GTS331
F5GTS331's Avatar
prime it like the last three told ya and youll be just fine
F5GTS331 is offline
Old 04-25-2007, 01:32 AM
CantStopTheFox...
Where do you plug the primer tool into? Is it the same place as where the distributor goes?
Old 04-25-2007, 01:39 AM
F5GTS331
F5GTS331's Avatar
well what i usually do is use the oil pump rod and put a socket and a drill on it and go from there. counterclockwise that is.
F5GTS331 is offline
Old 04-25-2007, 01:49 AM
LTnone
LTnone's Avatar
ORIGINAL: AdderMk2
Sound correct?
Or just use a 1/4" bit and an extension.. Duct tape them together, don't want them in your oilpan.
And like he said...DON'T turn the crank- that doesn't pump oil. Oil pumps do
LTnone is offline
jwog666
12-27-2021 08:09 PM
1TUFF302
11-05-2015 04:02 PM
wraith777
09-28-2015 10:49 AM
SteelerNation82
09-16-2015 07:11 AM
tramphardrocker
09-13-2015 08:56 PM
Quick Reply: How to Prime the Oil
